13 years agoChanging the play back rate of a buffer in C?
Hello! I am using an Altera DE2 FPGA board and running Quartus II, Nios II (V10.1). I loaded the Terasic V1.6 demo "DE2_SD_Card_Audio." Currently, I can play a .wav file from the SD card to t...
13 years agoHere are some options
-simple software delay loop -timer interrupt with a variable interrupt frequency based upon how fast you want to set the DAC -Software writes samples to a FIFO and statemachine, which writes data out to a DAC at a particular output rate specified by the software http://www.dspdimension.com/admin/time-pitch-overview/
