15 years agoChanging the bootloader HEX file in the NIOS II IDE
This is with NIOS II 8.1 although I'll be moving to 10.1 and will need to do this: I'm trying to use a custom bootloader (loaded in EPCS) without changing the hardware (in SOPC Builder). The r...
15 years agoYes, you can do that to.
See one of my more recent posts regarding just this issue in another thread. There's some C code that implements a simple bootloader expecting the boot record payload to be located at a fixed offset in the EPCS device rather than just after the SOF. Regards, -- slacker
