15 years agoChanging the bootloader HEX file in the NIOS II IDE
This is with NIOS II 8.1 although I'll be moving to 10.1 and will need to do this: I'm trying to use a custom bootloader (loaded in EPCS) without changing the hardware (in SOPC Builder). The r...
15 years agoThe SREC location that gets pulled in during EPCS component generation can vary, but for the last few versions (9.1 onwards) it's been at:
"$ENV{QUARTUS_ROOTDIR}/../ip/altera/nios2_ip/altera_nios2/boot_loader_epcs_sii_siii_ciii.srec" Incidentally, you can determine this for yourself by just looking at the em_epcs.pl Perl file responsible for generating the component. Best Regards, -- slacker
