22 years agoChanging location of .entry section
Hi, i'm working on a bootloader for a system with a Cyclone 1C6, Nios II/s,256kb SRAM and an Atmel serial dataflash (2 megabits). The bootloader will load the main application from the data...
22 years agoHow do you use nios2-elf-objdump to see where what's located. I tried nios2-elf-objdump -h xxx.elf.
That typed out alot of data, but I can't see that it should have changed anything changing to custom script. I tried changing the SDRAM from 0x1000000 to 0x1100000.
