20 years agochanged distributions, kernel not working..
My server suffered a little internal fire recently (note, fans are more valuable than you think!), so I had to setup a new box, and I decided to switch linux distributions from Slackware to Ubuntu. ...
20 years agojdhar,
Even in the 64-bit port of Quartus II on Linux, a fair amount of the tool runs in 32-bit mode. You can easily determine which binaries are 32-bit and which are 64-bit by performing a 'file' command on them. Now, directly to your question....most, if not all, of the toolchain is 32-bit code. It does successfully run on 64-bit architectures through a 32-bit "emulation" layer. I'm using an amd64 version of Gentoo Linux with no issues. I would suspect that you have some sort of installation or environment issue causing your problem. Cheers, - slacker
