19 years agochange UART port/pin assignments
Hi, I am working with a Nios II 2C35 dev board and I do not want to use the built-in serial port connector. I would like to use the J16 connector on the board to connect up RXD and TXD. I have ...
19 years agoYou don't need to change the SOPC builder
You can just change the pins assignment in Quartus, regenerate sof. If you change SOPC builder, you need to name the uart you want for console as "uart_0" . And run hwselect .
