13 years agochange link address
Bonjour I have a nioII/e in a cycloneIII+EPCS4 with only internal memory , an uart , a PIO and no debugger . It is run and I can dialog with the Uart , all is OK. But I must to compile with Quartu...
13 years agoI have found in linker.x
If we change reset ORIGINE and memory ORIGINE we obtain the code at the desired address ... For the proper hex file, modify mem_init.mk . At the command line to the creation of the HEX file add the option --no-zero-fill
