21 years agoCGI problems with Sh and Boa
My CGI get request is not working. Following the information on the form I used the shell script with the echo command to test the server side. 1. test.cgi will only run on th...
20 years agoAFAIK, the webserver in busybox needs to be run in a directory with cgi-bin in the path. As for the boa configuration, I'm not certain. I am sure it is documented properly.
This si what in my nios2 configuration (running C programs):Port 80
User root
Group root
ServerName www.board.com
DocumentRoot /home/webserver/
DirectoryIndex index.html
KeepAliveMax 1000
KeepAliveTimeout 10
MimeTypes /etc/mime.types
DefaultType text/plain
CGIPath /bin:/usr/bin:/usr/local/bin
ScriptAlias /cgi-bin/ /home/webserver/cgi-bin/ Check that /bin/ is in your CGIPath. I don't think that boa requires a certain extension to be a valid cgi script.
