praveenkumar
5 years agocfi flash using nios 2 flash programmer
i , i am trying to boot the cfi flash .
but first i want to debug whether it is working prperly or not .
i cannected genric tri state controller and conduit bridge and assigned pins in pin planne...
BoonBengT_Altera
Moderator
5 years agoHi @praveenkumar,
Just to add on, as mention in the other post on the board used which is cyclone ii.
You may refer to the following guide here for further details on how to configure the JTAG.
Please do let us know if that helps.
Best Wishes
BB
praveenkumar
5 years agoAs in below attached flow file i am getting an error like no cfi table found . i am using p33 micron nor flash rc 64 ball bga package .
i used tristate controller and tristate bridge .also have another doubt for this flash using dclk . we are clock for giving tristate controller . both clocks must be same or different or tristate controller clock will be sufficient for accesing the nor flash
