praveenkumar
5 years agocfi flash using nios 2 flash programmer
i , i am trying to boot the cfi flash .
but first i want to debug whether it is working prperly or not .
i cannected genric tri state controller and conduit bridge and assigned pins in pin planne...
BoonBengT_Altera
Moderator
5 years ago
Hi @praveenkumar,
Thank you for posting in Intel community forum, hope this message find you well and apologies for the delayed in response.
Would suggest to check on a few things 1) Check if the JTAG UART IP being added to the design 2) Board are connected to the PC and with the proper cable and driver installed (assume you are using Windows environment) 3) Check if the JTAG pin are connected correctly based on the board datasheet.
If possible please do share a screenshot on where the mention jtag error occurred.
Best Wishes
BB
