16 years agoCFI Flash doesn't read correcty after reset
I have a Stratix II GX with 2MBytes Flash in 8 bit mode and 512kBytes SRAM in 8 bit mode. The Flash memory is hooked up properly, in that most of my applications run just fine, but I'm having t...
16 years agoThe very first thing I would try is either a soft or hard reset to the flash. The flash most likely powers-up in read array mode. But truly you have no idea what state the flash is in if you perform a random reset. Issuing the write command puts the flash into a known state. Start with the reset and go from there.
Jake
