16 years agoCFI Flash doesn't read correcty after reset
I have a Stratix II GX with 2MBytes Flash in 8 bit mode and 512kBytes SRAM in 8 bit mode. The Flash memory is hooked up properly, in that most of my applications run just fine, but I'm having t...
16 years agoThe hardware reset signal to the flash memory is kept high at all times. This is true both in this design which doesn't work and other designs on the same board that do work.
Cheers, Simon
