20 years agoCFI-Flash & EPCS-programming in production
Hi, if the hardware consists of an EPCS device (for FPGA configuration) and a CFI-flash (for Nios software and serial number), how do I program both after hardware production via JTAG? In ...
20 years ago --- Quote Start --- originally posted by smcnutt@Jan 28 2006, 02:19 AM 3. on the stand-alone computer, copy nios2-flash-programmer.exe
into the directory <quartus ii stand-alone programmer path>/bin.
have you tried this? ... doesn't this work? what point am i missing here? --- Quote End --- This does not work. You must also copy cygwin1.dll to the same directory as nios2-flash-programmer. Otherwise the nios2-flash-programmmer will not work (tested with Nios II EDS 6.0).
