21 years agoCFI component for 16 bit Flashs in 8 bit mode
Hello, A custom board of mine is equipped with a 16-bit Flash from Fujitsu (AMD compatible). The Flash is used in 8-bit mode. Unfortunately it seems that the CFI component does not support 16-b...
21 years agoHello rugbybloke.
You mention a "host based executable". Do you know if it is possible to see the source code for that? And you mention a update 1.01 does it fix the problem with the "host based executable" as well? Goon
