21 years agoCFI component for 16 bit Flashs in 8 bit mode
Hello, A custom board of mine is equipped with a 16-bit Flash from Fujitsu (AMD compatible). The Flash is used in 8-bit mode. Unfortunately it seems that the CFI component does not support 16-b...
21 years agoHello niosIIuser.
I have a MBM29LV160-flash but I don't know if it is the flash that causes the flash programmer to fail or if it is something else. And just like you I modified the flash device driver with the correct 8-bit commands to support 8-bit writing. -- Goon --
