21 years agoCF interface
When I force safe board configuration on 1C20 dev board - can I expect the default software package in this board to use CF for any purpose? How can I see CF interface activity, not using uCLinux?
21 years agoPrior to Nios II.. Nios v3.2, etc., had compact flash defined (but not used) in the factory design (based on standard_32). It was not the best implementation - various PIOs and an interface to user logic. We took that out of Nios II 1.0 because of the component that Microtronix has provided (a much cleaner implementation); as stated above, try out their download. I believe that it includes example designs that define all the pins for you.
