21 years agoCF Data Transfer Bandwidth
A question to those who had given a test ride to the Microtronics CF component (in the Tested IP section of the forum): What data transfer bandwidth were you able to achieve? I know it depends ...
21 years agoHello Sandor
If I remeber correctly, I tried doing a raw data read bandwidth test, meaning, I was just reading sectors as fast aspossible, using the microtronix CF component. The results I got were around 6 Mbit/sec. This , however is only raw data read, with no file system. An MP3 design working from the CF can work with files of up to 160kbps, but I think the bottleneck is not the CF card. Regards Nir
