16 years agoCF card speed transfer
I would like to know what is the maximum speed transfert that I can obtain on the CF card with the altcf ip of ALTERA. Does anybody know if it's possible to change PIO mode ? Thank you in advance.12 Replies
I manage to obtain ~2.5MB/s. However is it possible to obtain a better data rate ?
Bye - Altera_Forum
Doing an appropriate DMA interface in "hardware" might help.
-Michael - Altera_Forum
How can you have DMA on altcf : there's two MM Slave : ctl and ide ?
I know that's possible to make a DMA request from SRAM two DDR but how can you do that from DDR to altcf ? Regards, - Altera_Forum
I meant: new "hardware" instead of altcf.
Building a new CF-port hardware processor that includes a state machine and some counters. Maybe using the DMA hardware blocks provided by Altera might be possible instead, but I have no knowledge on that. Of course a completely new Linux device driver for that DMA-CF-port is necessary as a consequence with either way. -Michael - Altera_Forum
Does anybody know how to implement the OCIDEC core on Avalon BUS?
This IP support the DMA process over IDE . Thank you Michael - Altera_Forum
AFAIK, there is an Avalon/Wishbone adapter somewhere...
Avalon/Wishbone adapter ?
That is very interresting. However I have look on google and I didn't found anything. Could you tell me where? - Altera_Forum
See
http://www.alterauserforums.org/forum/showthread.php?t=5500 and last mail in this thread: http://www.alteraforum.com/forum/showthread.php?t=2238 - Altera_Forum
Ok thank you...
So I have to translate the OCIDEC core from Wishbone to Avalon. However, do you thank that I will found driver for uClinux to drive my interface ? - Altera_Forum
I suppose there is no Linux-NIOS driver for DMA enabled CF. So you will need to create it.
-Michael
