19 years agoCF / Hard Drive Problems
I've been struggling to get the altcf module to work in the latest uClinux-dist environment (with hippo's patches), and I've run into two problems. 1) When I build the cf sample pro...
19 years ago1. I heard someone had the altcf working with the latest uClinux-dist.
2. I had displayed the IDE pin assignment using altcf core in CompactFlash wiki page. .addr_from_the_cf_0 (da), .cs_n_from_the_cf_0 (cs), .data_cf_to_and_from_the_cf_0 (dd), .detect_n_to_the_cf_0 (1'b0), .intrq_to_the_cf_0 (intrq), .iord_n_from_the_cf_0 (dior), .iordy_to_the_cf_0 (iordy), .iowr_n_from_the_cf_0 (diow), .reset_n_cf_from_the_cf_0 (reset) Remove unused pins of altcf. The key issue is the detect_n_to_the_cf_0 , which should be forced low for IDE.
