21 years ago
C,C++ support in NIOS
Will NIOS processor support all C & C++ instructions?
I have six C++ programs & a Verilog custom program. Each C++ program takes input from files generated by other C++ programs. Finally the data goes to FPGA(custom program)& gets the output.
Is there any restriction on data accessing from files. Each data is a floating number or an integer.
    --- Quote Start ---
    originally posted by mohana sundaram.s.v@Sep 1 2005, 07:58 AM
    hi,
    will nios processor support all c & c++ instructions?
    i have six c++ programs & a verilog custom program. each c++ program takes input from files generated by other c++ programs. finally the data goes to fpga(custom program)& gets the output.
    is there any restriction on data accessing from files. each data is a floating number or an integer.
    --- Quote End ---
    NIOS uses the standard gcc compiler with the newlib library
    If all the functions you use are available in the newlib library , then i see no reason why it should not work.
    Check the newlib lib documentaion in your nios install for a list of funcs
    regards
    Pavan
    I noticed the IDE doesn't indicate "class" to be a reserved word in a .c or .h file; I had assumed the compiler didn't support C++.
    The IDE does indicate "class" as a reserved word in a .cpp file. Is there a ".h-like" extension for which the IDE recognises "class" (.hpp?) ??
    Right click your project and select properties, then have a look at the "C/C++ File Types".
    --Scott
