20 years agocardbus WiFi card
Does anybody know if NDISWRAPPER works with uCLinux/NiosII ?
This wrapper is used to emulate NDIS Windows drivers ( http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif ) under Linux and is used mainly for Wifi cards. Since there is generally no Linux driver for such cards, I would like to know if it is possible to interface a CardBus (32 bit PCMCIA) compliant WiFi card with the Altera PCI IP, then use NDISWRAPPER using Windows driver. Any help or experience would be appreciated http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif1 Reply
--- Quote Start --- originally posted by bigboss25@Apr 25 2006, 12:04 AM does anybody know if ndiswrapper works with uclinux/niosii ?this wrapper is used to emulate ndis windows drivers ( http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/tongue.gif ) under linux and is used mainly for wifi cards.
since there is generally no linux driver for such cards, i would like to know if it is possible to interface a cardbus (32 bit pcmcia) compliant wifi card with the altera pci ip, then use ndiswrapper using windows driver.
any help or experience would be appreciated http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14608)
--- quote end ---
--- Quote End --- We can not use NDIS wrapper. They are x86 objecode. And can not run on nios2. You have to use a a card with portable driver source. You may check the intel's card drivers on sf.net . (I can't recall the project name.)
