14 years agoCan't synthesize Nios II without IP license
I'm trying to evaluate a Nios II design using Quartus II 11.1 sp1. I get the following error from Quartus: Error (204012): Can't generate netlist output files because the file <file> is an O...
14 years ago --- Quote Start --- I'm trying to evaluate a Nios II design using Quartus II 11.1 sp1. I get the following error from Quartus: Error (204012): Can't generate netlist output files because the file <file> is an OpenCore Plus time-limited file The KB says to turn off IBIS file generation to fix this but it's not on. All the documentation says that I should be able to evaluate a Nios II core without having to buy the license first. --- Quote End --- You can. Does the overall compile give you Success? Which file is it?
