21 years agoCan't run code out of flash!
I am trying to run my Nios II code from flash with no success. I can run from the IDE, no problem when program memory is in RAM. I then change the build for flash. The flash programmer works fine ...
21 years agoI thought you could just load code pretty much wherever you want, set the PC and GO!
Guess it's not that simple. After I'm done re-synthesizing, I'll get that objdump -h. What will that tell me? John
