21 years agoCan't run code out of flash!
I am trying to run my Nios II code from flash with no success. I can run from the IDE, no problem when program memory is in RAM. I then change the build for flash. The flash programmer works fine ...
21 years agoHi lemonoje,
Can you post your section info for the RAM code (e.g. objdump -h)? Regards, --Scott
