20 years agocan't run a project using the UART
Hi all-- I built a default "hello_world" project which references the "standard" example .ptf. I also chose the default setting to have a system library autogenerated. I then went into th...
20 years agoFor anyone who cares, this problem seems to have been just caused by a misconfiguration of the terminal software I was using. Apparently the nios2-terminal software gets told to use whatever port is chosen for "stdout." My terminal software was misconfigured, so apparently when nios2-terminal tried to output:
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) ...it didn't succeed, and responded with the "can't open uart" message. I love being new. Not. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif Brian
