15 years agoCan't Read Data from Custom componet (Avalon mm)
I had associated a custom component (A variation of the DCFIFO example available in AN 473) to my NIOS 2 System. I use the Avalon MM (Slave) Interface whit the current signals: Readdata (32bits...
15 years agoalt_dma_txchan_ioctl is a higher level HAL function ;).
With that code you will configure it to perform word transfers. And you will be constantly writing to the same address (tx_data_to) and the reading address increments by 0x04 after each read. You can use the code on page 29 of the document Daixiwen linked. Just add the configuration like this: if ((txchan = alt_dma_txchan_open("/dev/dma_0")) == NULL) { printf ("Failed to open transmit channel\n"); exit (1); } else { alt_dma_txchan_ioctl(txchan, ALT_DMA_SET_MODE_32, NULL); alt_dma_txchan_ioctl(txchan, ALT_DMA_TX_ONLY_ON, tx_data_to); alt_dma_txchan_ioctl(txchan, ALT_DMA_RX_ONLY_OFF, NULL); }
