15 years agoCan't Read Data from Custom componet (Avalon mm)
I had associated a custom component (A variation of the DCFIFO example available in AN 473) to my NIOS 2 System. I use the Avalon MM (Slave) Interface whit the current signals: Readdata (32bits...
15 years agoHi daixiwen.
Our problem is: we need to detect the change of the signal read_i. 1) We send a irq request. 2) The Avalon Master detects our request, so, it asserts the read_i and we need to desassert irq_req. 3) When the device stops the reading, it dessaserts read_i, and then we have to go to INCADR state, to get the next data from a FIFO and putting it as output. I can't understand how I could do it the way you said. Thanks.
