15 years agoCan't Read Data from Custom componet (Avalon mm)
I had associated a custom component (A variation of the DCFIFO example available in AN 473) to my NIOS 2 System. I use the Avalon MM (Slave) Interface whit the current signals: Readdata (32bits...
15 years agoHi again,
I just read your thread again. I´m not really sure wheres your problem but I wanted to help you. I created a really simple read & write component for SOPC builder. I attached the screen of the SOPC, the main.c programm I tested the component with and the Verilog file with the tcl file. If you use the component with my tcl you should not get any problems to read or write from it.
