15 years agoCan't Read Data from Custom componet (Avalon mm)
I had associated a custom component (A variation of the DCFIFO example available in AN 473) to my NIOS 2 System. I use the Avalon MM (Slave) Interface whit the current signals: Readdata (32bits...
15 years agoThat's really strange... Are you sure that your component is connected to the Nios data master port? In the component editor, are you sure that data_o is defined as readdata on the slave interface?
