19 years agoCan't open ttyS0 !!!
Hi All ! I used 2s60ES and build uclinux for my board . I wrote simple example relate with UART this is my code : struct termios options; fd=open("/dev/ttyS0",O_RDWR ); if(fd==-...
19 years agoDid you enable nios uart driver in kernel config?
If you already run console or shell on the uart, you can't open it again. use stdin/out instead. Otherwise, try "cp /etc/motd /dev/ttyS0" .
