20 years agoCan't open PTF file
Hello all I have modified cpu cloclk to 100Mhz in SOPC Builder and cup input singal conneted from c1 of SDRAM PLL,then generate new ptf. But I could not open PTF file under uClinux-dist-test di...
20 years ago --- Quote Start --- originally posted by jay_1025@Jun 21 2006, 06:52 PM hello all
i have modified cpu cloclk to 100mhz in sopc builder and cup input singal conneted from c1 of sdram pll,then generate new ptf.
but i could not open ptf file under uclinux-dist-test dir.
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
[faye@localhost uclinux-dist-test]$ make linux_hwselect sysptf=nios_clk100.ptf
kconfig_notimestamp=1 make arch=nios2nommu cross_compile=nios2-linux-uclibc- arch=nios2nommu cross_compile=nios2-linux-uclibc- -c linux-2.6.x hwselect
no emulation specific options.
make[1]: entering directory `/home/faye/uclinux-dist-test/linux-2.6.x'
running hwselect
error: could not open system ptf file.
make[1]: leaving directory `/home/faye/uclinux-dist-test/linux-2.6.x' --- Quote End --- Do you know how to solve this problem ? Thx ! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16313)</div> [/b] --- Quote End --- Please give the path of the ptf, eg, SYSPTF=~/proj_100/nios2_clk100.ptf
