16 years ago
Can't open CFI Flash from NIOS
I use Numonix PF48F2000 Flash as configuration device in Active parallel mode, but also need to access it from the application. The configuration part works just fine, however access to the Flash through the API (alt_flash_open_dev ) fails. I have no problems reading/writing to EPCS device with the same functions.
My configuration: Cyclone III, Quartus 9SP2.
Thank you.
    I think you must check the altera_avalon_cfi_flash_table.c file and other altera_avalon_cfi_flash*.* files located in \altera\90sp2\nios2eds\... and in \altera\90sp2\ip\...
    Probably there is no CFI entry for your device and you simply need to add it.
    You can build the syslib in debug mode and step into alt_flash_open_dev() in order to find the exact point where the function fails.
    Cris
    Thanks Cris, it's exactly the case. Will have to make my Flash recognizable.
