11 years agoCan't finish creating NiosII project
Hi Everyone. I would be grateful if someone could help me with this one: I have followed this video tutorial step by step: https://www.youtube.com/watch?v=1a_cd6fbroa I have made the sam...
11 years agoOK. Here is my last idea:
Read the following thread: http://www.alterawiki.com/wiki/new_qsys_issues#nios_bsp_and_projects_fail_to_make_on_win7 Here is the relevant excerpt: "Nios BSP and Projects fail to make on Win7 Issue: NIOS make files fail to run correctly under Windows 7 via Eclipse or command line. This affects the generation of BSP's and compilation of regular projects. The problem seems to be with file/directory permissions under the cygwin environment. Fix: Run Eclipse or the command prompt as administrator. (Right click to get context menu, select "Run as administrator".)" Hope this helps. Good luck.
