11 years agoCan't finish creating NiosII project
Hi Everyone. I would be grateful if someone could help me with this one: I have followed this video tutorial step by step: https://www.youtube.com/watch?v=1a_cd6fbroa I have made the sam...
11 years agoHi Krasner,
I am able to compile the project with no flaws, which I did before trying to create the Eclipse project, and both Quartus and this project are on folders with no space on the file names. Not sure if I can switch to any version of Quartus greater than 13.0sp1, because my boards (DE1, DE2 and DE2-70) all use the CycloneII chip, which is not supported. Unless there's a way to add that support manually to 13.1. I will try removing Quartus completely and re-installing it, maybe it helps. Not sure at this point what the issue may be. [edit] Do you think this may be related to the operating system? not running something as "administrator"? Thanks a lot for the help. Any other ideas are most welcome. Cheers, Marcelo.
