12 years agoCan't boot with code in sdram
I've made a sopc system in which the niosii cpu's reset vector is in cfi_flash and exception vector is in sdram. I can run and debug my program in eclipse very well, but when I use flash programme...
12 years agoThe problem is solved, I'm using sdram K4S641632k. I know that the problem is very likely related to the byte enable signal.
So I double checked the ldqm and udqm signal of sdram, it's connected to the fpga correctly. I was shocked ten minutes ago when the pcb designer tell me he had switched the high/low byte signals of sdram for easy routing.
