20 years agoCan't boot uClinux from the EPCS & CFI Flash?
According to the
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) When I try the 7th step ,I found can't boot uClinux from EPCS & CFI Flash,the prevous step is OK. The problem of boot from EPCS: the nios2-flash-programmer of zImage is OK,when reset the system,the Hardware may be configured successfully,but how Do I know the uClinux is start successfully? The problem of boot from CFI Flash: when use the nios2-flash-programmer programmer ,it promot:input file is too large to fit,and how Do I know the uClinux is start successfully,too? Is someone have pass the step successfully? Need your help! Thanks!1 Reply
--- Quote Start --- originally posted by gaobing@Jul 6 2006, 05:37 PM according to thehttp://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
when i try the 7th step ,i found can't boot uclinux from epcs & cfi flash,the prevous step is ok.
the problem of boot from epcs:
the nios2-flash-programmer of zimage is ok,when reset the system,the hardware may be configured successfully,but how do i know the uclinux is start successfully?
the problem of boot from cfi flash:
when use the nios2-flash-programmer programmer ,it promot:input file is too large to fit,and how do i know the uclinux is start successfully,too?
is someone have pass the step successfully? need your help!
thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16684)
--- quote end ---
--- Quote End --- Please read in the middle of the nios wiki, about DE2 difference, http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operatingsystems/flashprogrammer)
