16 years agocan't boot from epcs to external sram
Hello, I have a problem while booting a niosII program from epcs4 to external external sram (1Mx16bit). My sopc system is composed of the following parts: 1) niosII processor, with rese...
14 years ago --- Quote Start --- MSchmitt, you're so smart! Without your hint, I would never find a clue out from the complex asm codes. Just as what you have said, the default boot loader can't access 16-bits srams. After I transform my sram to 8-bit width, everything is ok. Thanks for your rapid help. Well, to help others avoid making the same mistakes that I have made while programing epcs, I'd like to list my mistakes: 1) Forgot assigning AS pins as regular IO, which is necessary for cyclone III. 2) Use JTAG other than AS mode; 3) The problem described in this post. --- Quote End --- hi, zuo, i have the same pb, could you tell me where can i find a sram controler of 8 bit thx
