16 years agocan't boot from epcs to external sram
Hello, I have a problem while booting a niosII program from epcs4 to external external sram (1Mx16bit). My sopc system is composed of the following parts: 1) niosII processor, with rese...
16 years agoMSchmitt, you're so smart! Without your hint, I would never find a clue out from the complex asm codes.
Just as what you have said, the default boot loader can't access 16-bits srams. After I transform my sram to 8-bit width, everything is ok. Thanks for your rapid help. Well, to help others avoid making the same mistakes that I have made while programing epcs, I'd like to list my mistakes: 1) Forgot assigning AS pins as regular IO, which is necessary for cyclone III. 2) Use JTAG other than AS mode; 3) The problem described in this post.
