20 years agoCan't access the Main function!
Hi community:
Now i encounter a really strange problem. I develop a nios system. It contains SDram, Sram, Flash, and other module. There is no error while i compile it in SOPC and Quartus. When i start a Hello LED project in NIOS IDE, the Alt_main is the entry of the program, everything goes well. No matter i Debug this program in both of the Ram(Sram, SDram) , or i download the .elf to the FLASH and let the program start from FLASH, the LED program runs pretty well. BUT, when i start a new project HELLO WORLD, the main is the entry , trouble comes out!! (This HELLO WORLD project can only print a string "HELLO" using the stdout. ) The compile process finishes without any error. But after i press the DEBUG button, the program seems keeping "running" without stop in the Main function. And the "Step into, Step over, Step run" icon is gray that can't be pressed. I just wonder where is the current PC. So i press the "Suspend" button. The PC jump between alt_irq.h and alt_irq_handler.c over and over. In detail, the PC always jump from this section below in alt_irq.h static ALT_INLINE alt_u32 ALT_ALWAYS_INLINE alt_irq_pending (void) { alt_u32 active; NIOS2_READ_IPENDING (active); return active; } to this section below in alt_irq_hander.c void alt_irq_handler (void) { alt_u32 active; alt_u32 mask; alt_u32 i; /* * Notify the operating system that we are at interrupt level. */ ALT_OS_INT_ENTER(); /* * Obtain from the interrupt controller a bit list of pending interrupts, * and then process the highest priority interrupt. This process loops, * loading the active interrupt list on each pass until alt_irq_pending() * return zero. * * The maximum interrupt latency for the highest priority interrupt is * reduced by finding out which interrupts are pending as late as possible. * Consider the case where the high priority interupt is asserted during * the interrupt entry sequence for a lower priority interrupt to see why * this is the case. */ active = alt_irq_pending (); do { i = 0; mask = 1; /* * Test each bit in turn looking for an active interrupt. Once one is * found, the interrupt handler asigned by a call to alt_irq_register() is * called to clear the interrupt condition. */ do { if (active & mask) { alt_irq.handler(alt_irq.context, i); break; } mask <<= 1; i++; } while (1); active = alt_irq_pending (); } while (active); /* * Notify the operating system that interrupt processing is complete. */ ALT_OS_INT_EXIT(); } and once go over the if(active & mask) in loop do { if (active & mask) { alt_irq.handler(alt_irq.context, i); break; } mask <<= 1; i++; } while (1); the next time will go into the if(active & mask) and break. and now the pc return to the section i mentioned first time in alt_irq.h static ALT_INLINE alt_u32 ALT_ALWAYS_INLINE alt_irq_pending (void) { alt_u32 active; NIOS2_READ_IPENDING (active); return active; } So, here comes out a infinite loop. And the program will never go to the Main() function. Why? And how to fix it? I would like to offer some information further more. 1). The SDRAM, SRAM, FLASH works! Because in the HELLO_LED program, i let the program located in the SDRAM, SRAM and the program can run. 2). This situation is not all along. I mean the HELLO_WORLD program did work in the first time i debug it. But from i debug it in the next day till now, it is dead. Please give me some advice, or solution. I will reply the information you needed as soon as possible. Thanks all of U. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Kevin.Lee2 Replies
It is enough to have an exercise with hello .
Then you should jump start on uClinux. http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux) There is no need to spend much time on HAL API. - Altera_Forum
Hippo's right, if uCLinux is what you'd like run, eventually. Since you didn't post this to the uCLinux Forum, I'm assuming that you don't want to run uCLinux. So, here are my questions:
Which interrupt is causing this problem? Also, does the initialization code, for your devices, function? (Hint: step through the code in alt_sys_init.c) You mentioned that you had it working, at one point. What have you changed? Best of luck, - slacker
