hyang73
5 years agoCannot use override file for "no epcs layout data" error
Hi there,
I'm using Quartus 17.0 Lite Edition and EDS for SOPC learning, device that I'm using is EP4CE10F17C8. I created a nios2/e based system and a hello_ucos project. When I used flash programm...
JohnT_Altera
5 years agoHi,
May I know which IP are you using to interface with the flash? If you using older IP then I would recommend you to update to Generic Serial Flash Interface IP (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-gen-sfi.pdf) which will support 3rd party flash.
hyang73
5 years agoHi,
I cannot find generic serial flash interface in IP catalog... maybe it is not released to Qsys?
The IP I'm using is Legacy EPCS Flash Controller.
