15 years agoCannot Run or Debug NIOS
Hi, I can't Run or Debug my NIOS system from the NIOS EDS v10.1 (10.0 sp1 didn't work either). When I try to Run, I get a "Downloading ELF Process Failed" error. It says that verify failed...
15 years agoI've seen this error when the Nios II data and instruction masters are not BOTH connected to the instruction memory. I believe nios2-download uses the data master to program instruction memory.
