19 years ago
cannot open root device
Hello All !
I built Kernel success on platform linux . but I got error when I load kernel to board .
.... cannot open root device "NULL" or unknown-block(0,0)
please append a correct "root =" boot option
kernel panic - not syncing : VFS: unable to mount root fs on unknown-block(0,0)
I think need to modify "Default kernel command string" when I configure kernel is it correct ? and I don't know how to modify that . please help me !!!
thanks .
    --- Quote Start ---
    originally posted by dai_minh@Nov 20 2006, 03:35 PM
    hi hippo !
    yes i think it have problem when install romfs . but how is it resolve ?
    i use fedora core 5 .
    thank very much for help !!!
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19531)
    --- quote end ---
    --- Quote End ---
    I will check fc5 later.
    Please run "make romfs" again, and check the romfs dir.
    Hi Hippo .
    thanks for quick reply !
    I did "rm -rf romfs" and "make romfs " again but result is same . romfs/bin is empty .
    thanks .
    --- Quote Start ---
    originally posted by hippo+nov 20 2006, 02:39 am--><div class='quotetop'>quote (hippo @ nov 20 2006, 02:39 am)</div>
    --- quote start ---
    <!--quotebegin-dai_minh@Nov 20 2006, 03:35 PM
    hi hippo !
    --- quote end ---
    --- Quote End ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19532)</div>
    [/b]
    --- Quote End ---
    I had the same problem. I fixed it by specifying the path to the boot image. For some reason it was poininting to something else. When one starts specifying the Kernel options, one of the entries idicates where that image is. I don&#39;t have the machine next to me, so I can not tell you where exactly it is. Sorry.
    --- Quote End ---
    --- Quote End ---
    Hello .
    thank for help !
    You fixed it by specifying the path to the boot Image . you mean is modify "Default kernel command string"
    and How about your romfs dir . the most subdir in my romfs dir is empty except romfs/etc and romf/home .
    thanks .
