19 years agocannot open root device
Hello All ! I built Kernel success on platform linux . but I got error when I load kernel to board . .... cannot open root device "NULL" or unknown-block(0,0) please append a correct "r...
19 years ago --- Quote Start --- originally posted by vietluong+nov 20 2006, 12:20 pm--><div class='quotetop'>quote (vietluong @ nov 20 2006, 12:20 pm)</div>
--- quote start ---
<!--quotebegin-hippo@Nov 19 2006, 10:36 PM it looks like the initramfs was empty,
please check if you have files in romfs/bin ?
please check initramfs content as in the wiki page,
http://nioswiki.jot.com/wikihome/operating...initramfsupdate (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/initramfsupdate)
which linux distro do you use?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19527)
--- quote end ---
--- Quote End --- Hi hippo ! yes . I don't have any file in romfs/bin . I build kernel on Linux platform . I have 3 file : nios2gcc.tar.bz2 + uClinux-dist-20060803.tar.bz2 + uClinux-dist-200608003-nios2-02.diff.gz and i did step by step in uclinux-dist wiki page . I think some file is wrong ? is it correct !!! thanks ! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19528)</div> [/b] --- Quote End --- What Linux platform do you use? It maybe romfs install problem. Check if busybox built, ls -l user/busybox/busybox
