19 years agocannot open root device
Hello All ! I built Kernel success on platform linux . but I got error when I load kernel to board . .... cannot open root device "NULL" or unknown-block(0,0) please append a correct "r...
19 years ago --- Quote Start --- originally posted by vietluong@Nov 19 2006, 12:09 PM hi hippo !
i did but i got the same message error .
tcp: hash tables configured (established 1024 bind 1024)tcp reno registeredio scheduler noop registeredio scheduler deadline registered (default)serial: jtag uart driver $revision: 1.1 $ttyj0 at mmio 0x80801080 (irq = 2) is a jtag_uarttcp bic registerednet: registered protocol family 1net: registered protocol family 17vfs:
Cannot open root device "<NULL>" or unknown-block(0,0) Please append a correct "root=" boot optionKernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)[/b] " I have uClinux-dist/romfs dir but romfs/bin and romfs/dev ,./lib ,../ mnt ,../proc ,../sys ,../tmp ,../usr , ../var dir is empty --> what wrong ???? thanks . <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19515) --- Quote End --- [/b] --- Quote End --- Please restore to default setting, and try again, make clean make menuconfig Kernel/Library/Defaults Selection ---> (linux-2.6.x) Kernel Version (None) Libc Version [*] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Vendor/User Settings [ ] Update Default Vendor Settings Then <exit> <exit> <yes> do not change any other setting until first boot successfully.
