20 years ago
Cannot connect to target
I am new to this forum.
I am using Nios II evaluation kit and following the user guide to run a helloworld program. I hasinstalled USB blaster driver on my WinXP (home edition) so I am able to connect to the target (using nios2-terminal), login and setup an IP address using DHCP.
This did last long.
The terminal program aborted a few minutes later indicating a I/O error. This problem very repeatable. I am also unable to use Nios IDE to programm the helloworld program on the target because it complains JTAG errors.
Any pointers would be welcome. Thanks.
Aaron
    I have resolved the problem myself - 1. possibly a loose cable connection. 2. I forgot to program the FPGA chip before runing the helloworld program.
    Well, first experience with Nios II not too bad...
    --- Quote Start ---
    originally posted by aaronjin@Apr 12 2006, 09:42 AM
    i am new to this forum.
    i am using nios ii evaluation kit and following the user guide to run a helloworld program. i hasinstalled usb blaster driver on my winxp (home edition) so i am able to connect to the target (using nios2-terminal), login and setup an ip address using dhcp.
    this did last long.
    the terminal program aborted a few minutes later indicating a i/o error. this problem very repeatable. i am also unable to use nios ide to programm the helloworld program on the target because it complains jtag errors.
    any pointers would be welcome. thanks.
    aaron
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14283)
    --- quote end ---
    --- Quote End ---
