19 years agoCannot configure kernel
when trying to configure uclinux kernel in ide 6.1 i get the follwing output/error:
arch/nios2nommu/Kconfig:220: syntax error, unexpected T_WORD arch/nios2nommu/Kconfig:221: invalid menu option arch/nios2nommu/Kconfig:221: syntax error, unexpected T_WORD arch/nios2nommu/Kconfig:222: invalid menu option drivers/pci/Kconfig:14: syntax error, unexpected T_WORD drivers/pci/Kconfig:17: invalid menu option drivers/pci/Kconfig:17: syntax error, unexpected T_BOOLEAN drivers/pci/Kconfig:18: invalid menu option drivers/pci/Kconfig:18: syntax error, unexpected T_DEPENDS drivers/pci/Kconfig:19: invalid menu option drivers/pci/Kconfig:19: syntax error, unexpected T_HELP drivers/pci/Kconfig:20: invalid menu option drivers/pci/Kconfig:20: syntax error, unexpected T_WORD drivers/pci/Kconfig:34: invalid menu option drivers/pci/Kconfig:34: syntax error, unexpected T_BOOLEAN drivers/pci/Kconfig:35: invalid menu option drivers/pci/Kconfig:35: syntax error, unexpected T_DEPENDS drivers/pci/Kconfig:36: invalid menu option drivers/pci/Kconfig:36: syntax error, unexpected T_HELP drivers/pci/Kconfig:37: invalid menu option drivers/pci/Kconfig:37: syntax error, unexpected T_WORD drivers/pci/Kconfig:38: invalid menu option drivers/pci/Kconfig:38: syntax error, unexpected T_WORD drivers/pci/Kconfig:43: invalid menu option drivers/pci/Kconfig:44: syntax error, unexpected T_WORD drivers/pci/Kconfig:45: invalid menu option drivers/pci/Kconfig:45: syntax error, unexpected T_WORD arch/nios2nommu/Kconfig:251: invalid menu option arch/nios2nommu/Kconfig:251: syntax error, unexpected T_BOOLEAN arch/nios2nommu/Kconfig:252: invalid menu option arch/nios2nommu/Kconfig:252: syntax error, unexpected T_HELP arch/nios2nommu/Kconfig:253: invalid menu option arch/nios2nommu/Kconfig:253: syntax error, unexpected T_WORD arch/nios2nommu/Kconfig:254: invalid menu option arch/nios2nommu/Kconfig:254: syntax error, unexpected T_WORD arch/nios2nommu/Kconfig:269: invalid menu option drivers/pci/hotplug/Kconfig:17: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:23: invalid menu option drivers/pci/hotplug/Kconfig:23: syntax error, unexpected T_TRISTATE drivers/pci/hotplug/Kconfig:24: invalid menu option drivers/pci/hotplug/Kconfig:24: syntax error, unexpected T_DEPENDS drivers/pci/hotplug/Kconfig:25: invalid menu option drivers/pci/hotplug/Kconfig:25: syntax error, unexpected T_HELP drivers/pci/hotplug/Kconfig:26: invalid menu option drivers/pci/hotplug/Kconfig:26: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:27: invalid menu option drivers/pci/hotplug/Kconfig:27: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:28: invalid menu option drivers/pci/hotplug/Kconfig:28: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:46: invalid menu option drivers/pci/hotplug/Kconfig:46: syntax error, unexpected T_TRISTATE drivers/pci/hotplug/Kconfig:47: invalid menu option drivers/pci/hotplug/Kconfig:47: syntax error, unexpected T_DEPENDS drivers/pci/hotplug/Kconfig:48: invalid menu option drivers/pci/hotplug/Kconfig:48: syntax error, unexpected T_HELP drivers/pci/hotplug/Kconfig:49: invalid menu option drivers/pci/hotplug/Kconfig:49: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:50: invalid menu option drivers/pci/hotplug/Kconfig:50: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:58: invalid menu option drivers/pci/hotplug/Kconfig:58: syntax error, unexpected T_BOOLEAN drivers/pci/hotplug/Kconfig:59: invalid menu option drivers/pci/hotplug/Kconfig:59: syntax error, unexpected T_DEPENDS drivers/pci/hotplug/Kconfig:60: invalid menu option drivers/pci/hotplug/Kconfig:60: syntax error, unexpected T_HELP drivers/pci/hotplug/Kconfig:61: invalid menu option drivers/pci/hotplug/Kconfig:61: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:62: invalid menu option drivers/pci/hotplug/Kconfig:62: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:68: invalid menu option drivers/pci/hotplug/Kconfig:68: syntax error, unexpected T_TRISTATE drivers/pci/hotplug/Kconfig:69: invalid menu option drivers/pci/hotplug/Kconfig:69: syntax error, unexpected T_DEPENDS drivers/pci/hotplug/Kconfig:70: invalid menu option drivers/pci/hotplug/Kconfig:70: syntax error, unexpected T_HELP drivers/pci/hotplug/Kconfig:71: invalid menu option drivers/pci/hotplug/Kconfig:71: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:72: invalid menu option drivers/pci/hotplug/Kconfig:72: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:80: invalid menu option drivers/pci/hotplug/Kconfig:80: syntax error, unexpected T_TRISTATE drivers/pci/hotplug/Kconfig:81: invalid menu option drivers/pci/hotplug/Kconfig:81: syntax error, unexpected T_DEPENDS drivers/pci/hotplug/Kconfig:82: invalid menu option drivers/pci/hotplug/Kconfig:82: syntax error, unexpected T_HELP drivers/pci/hotplug/Kconfig:83: invalid menu option drivers/pci/hotplug/Kconfig:83: syntax error, unexpected T_WORD drivers/pci/hotplug/Kconfig:84: invalid menu optionmake[3]: *** [menuconfig] Int errupt make[2]: *** [menuconfig] Interrupt make[1]: *** [menuconfig] Interrupt make: *** [menuconfig] Interrupt /cygdrive/d/temp/bla/build [SOPC Builder]$ ls Makefile a.exe* arch/ bla.txt mconf.exe.stackdump scripts/ /cygdrive/d/temp/bla/build [SOPC Builder]$ cat bla.txt make -C /cygdrive/d/ECAD/Altera/V61/nios2eds/bin/eclipse/plugins/com.microtronix .nios2linux.kernel_1.4.0/linux-2.6.x O=/cygdrive/d/Temp/bla/build menuconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/basic/split-include HOSTCC scripts/basic/docproc GEN /cygdrive/d/Temp/bla/build/Makefile HOSTLD scripts/kconfig/mconf HOSTLD scripts/lxdialog/lxdialog scripts/kconfig/mconf arch/nios2nommu/Kconfig init/Kconfig:37:warning: multi-line strings not supported init/Kconfig:146:warning: multi-line strings not supported init/Kconfig:223:warning: multi-line strings not supported drivers/block/Kconfig:236:warning: multi-line strings not supported drivers/ide/Kconfig:110:warning: multi-line strings not supported drivers/ide/Kconfig:299:warning: multi-line strings not supported drivers/ide/Kconfig:558:warning: multi-line strings not supported drivers/ide/Kconfig:845:warning: multi-line strings not supported drivers/scsi/Kconfig:735:warning: multi-line strings not supported drivers/scsi/Kconfig:1089:warning: multi-line strings not supported net/Kconfig:496:warning: multi-line strings not supported drivers/net/Kconfig:32:warning: multi-line strings not supported drivers/net/arcnet/Kconfig:98:warning: multi-line strings not supported drivers/net/wan/Kconfig:82:warning: multi-line strings not supported drivers/atm/Kconfig:357:warning: multi-line strings not supported drivers/atm/Kconfig:385:warning: multi-line stringsmake -C /cygdrive/d/ECAD/Alte ra/V61/nios2eds/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linu x-2.6.x O=/cygdrive/d/Temp/bla/build menuconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/basic/split-include HOSTCC scripts/basic/docproc GEN /cygdrive/d/Temp/bla/build/Makefile HOSTLD scripts/kconfig/mconf HOSTLD scripts/lxdialog/lxdialog scripts/kconfig/mconf arch/nios2nommu/Kconfig /cygdrive/d/temp/bla/build [SOPC Builder]$ http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif1 Reply
I'm assuming you're referring to the Microtronix version of uCLinux. If so, then please read their documentation, where I hope you'll find which version of the IDE (and toolchain) is supported. 6.1, most certainly, is NOT.
Best Regards, - slacker
