19 years agocannot compile bash or net-snmp
Hi, I am trying to compile bash with the latest uClinux toolchain, but I get an error when trying to link the libraries: nios2-linux-uclibc-gcc -L./builtins -L./lib/readline -L./lib/read...
17 years ago<div class='quotetop'>QUOTE (hippo @ Jan 18 2007, 08:27 PM) <{post_snapback}> (index.php?act=findpost&pid=20703)</div>
--- Quote Start --- 1. you need to add "#include <strings.h>" in the source for bcopy. 2. you need to modify the Makefile to remove .so targets.[/b] --- Quote End --- Could you tell me which makefile and how? I am trying to build net-snmp but it fails:...
nios2-linux-uclibc-ranlib .libs/libnetsnmphelpers.a
creating libnetsnmphelpers.la
(cd .libs && rm -f libnetsnmphelpers.la && ln -s ../libnetsnmphelpers.la libnetsnmphelpers.la)
: libnetsnmphelpers.la
make: Leaving directory `/home/caleb/nios2-linux/uClinux-dist/user/net-snmp/build/agent/helpers'
making all in /home/caleb/nios2-linux/uClinux-dist/user/net-snmp/build/agent/mibgroup
echo timestamp > mibgroup/mibII/vacm_conf.lo
make: Entering directory `/home/caleb/nios2-linux/uClinux-dist/user/net-snmp/build/agent/mibgroup'
make: Leaving directory `/home/caleb/nios2-linux/uClinux-dist/user/net-snmp/build/agent/mibgroup'
echo timestamp > snmpd.lo
make: Leaving directory `/home/caleb/nios2-linux/uClinux-dist/user/net-snmp/build/agent'
make: *** Error 1
make: Leaving directory `/home/caleb/nios2-linux/uClinux-dist/user/net-snmp/build'
make: *** Error 2
make: Leaving directory `/home/caleb/nios2-linux/uClinux-dist/user/net-snmp'
make: *** Error 2
make: Leaving directory `/home/caleb/nios2-linux/uClinux-dist/user'
make: *** Error 2
make: *** Error 1 Thanks. P.s. am I in a time warp? The forum seems to have lost everything after 2007 and I had to remake my login?
