11 years agoCannot build root filesystem using Buildroot on Ubuntu 14.10
I'm building Linux kernel and root filesystem for Arrow SoCKit. I've installed cross compiler on Ubuntu 14.10 machine: $ sudo apt-get install gcc-arm-linux-gnueabihf $ arm-linux-gnueabihf-gcc --version arm-linux-gnueabihf-gcc (Ubuntu/Linaro 4.9.1-16ubuntu6) 4.9.1 Copyright (C) 2014 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. The cross-compiler works. I've used it to build kernel for Arrow SoCKit: $ make CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm socfpga_defconfig $ alias armmake='make CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm' <--I put this into .profile $ armmake -j4 uImage LOADADDR=0x8000 <-- this produced the expected uImage But then I run into problem trying to build root fs for SoCKit using Buildroot-2014.11: $ make menuconfig Within Buildroot menuconfig I set the Toolchain as follows: Toolchain type (External toolchain) ---> Toolchain (Custom toolchain) ---> Toolchain origin (Pre-installed toolchain) ---> (/usr/) Toolchain path (arm-linux-gnueabihf) Toolchain prefix External toolchain kernel headers series (3.1.x) ---> External toolchain C library (glibc/eglibc) ---> [*] Toolchain has RPC support? [*] Toolchain has C++ support? () Extra toolchain libraries to be copied to target [ ] Copy gdb server to the Target [ ] Build cross gdb for the host [ ] Purge unwanted locales () Generate locale data [ ] Copy gconv libraries [*] Enable MMU support (-pipe) Target Optimizations () Target linker options [ ] Register toolchain within Eclipse Buildroot plug-in Then run make and get the following error: $ make /usr/bin/make -j1 HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" silentoldconfig make[1]: Entering directory '/home/jeff/buildroot-2014.11' BR2_DEFCONFIG='' KCONFIG_AUTOCONFIG=/home/jeff/buildroot-2014.11/output/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/jeff/buildroot-2014.11/output/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/jeff/buildroot-2014.11/output/build/buildroot-config/tristate.config BR2_CONFIG=/home/jeff/buildroot-2014.11/.config BR2_EXTERNAL=support/dummy-external /home/jeff/buildroot-2014.11/output/build/buildroot-config/conf --silentoldconfig Config.in make[1]: Leaving directory '/home/jeff/buildroot-2014.11' >>> toolchain-external undefined Configuring cc1: fatal error: /usr/arm-linux-gnueabihf//usr/include/linux/version.h: No such file or directory compilation terminated. support/scripts/check-kernel-headers.sh: 38: support/scripts/check-kernel-headers.sh: /tmp/check-headers.uAeguv: Permission denied package/pkg-generic.mk:172: recipe for target '/home/jeff/buildroot-2014.11/output/build/toolchain-external-undefined/.stamp_configured' failed make: *** [/home/jeff/buildroot-2014.11/output/build/toolchain-external-undefined/.stamp_configured] Error 1 I've used Buildroot in Arch Linux without encountering the above problem. I'm new to Ubuntu, and can't figure out what is going wrong. Can anyone help? Thanks!No RepliesBe the first to reply
