Tool's avatar
Tool
3 years ago
Cannot build a project in Nios
I cannot Build Project or Clean Project. I get an error right away. I have an example of an error below from a Clean Project.
11:31:59 **** Clean-only build of configuration Nios II for project Application ****
make clean
The system cannot find the path specified.
'uname' is not recognized as an internal or external command,
operable program or batch file.
process_begin: CreateProcess(NULL, rm -f -r Application.elf Application.objdump Application.map obj obj/default/runtime obj/default/.force_relink obj/default/.force_rebuild .force_rebuild_all, ...) failed.
make (e=2): The system cannot find the file specified.
make: *** [clean] Error 2
11:31:59 Build Finished (took 405ms)
I have WSL installed. What else do I need? I am using Quartus 22.1 Standard Edition. I can compile the FPGA fine in Quartus and generate a BSP.
  • KennyT_altera's avatar
    KennyT_altera
    Kindly note that there will be some slowness on the first reply due to the public holiday, we will get back to you as soon as possible.
  • hareesh's avatar
    hareesh
    can you please share the log file?
    • Tool's avatar
      Tool
      I attached some log file, so is this the file are you asking for? I do see what is below in the Console.
      09:23:21 **** Build of configuration Nios II for project AppNios ****
      make all
      'sed' is not recognized as an internal or external command,
      make: *** [build_pre_process] Error 1
      09:23:24 Build Finished (took 2s.356ms)
  • hareesh's avatar
    hareesh
    sorry for delaying. because of my workload, I am not able to get back to you. mostly today or tomorrow I will try to respond to you.
    Thank you,
  • hareesh's avatar
    hareesh
    in a log file, I didn't find any information. simply it saying eclipse launch field.
    I need to discourse in the call. can you please update me when you will be available to arrange a call?
  • hareesh's avatar
    hareesh
    can you please update the status of your issue?
  • hareesh's avatar
    hareesh
