Tool
3 years agoCannot build a project in Nios
I cannot Build Project or Clean Project. I get an error right away. I have an example of an error below from a Clean Project.
11:31:59 **** Clean-only build of configuration Nios II for project App...
hareesh
3 years agoHi,
can you please share the log file?
Tool
3 years agoI attached some log file, so is this the file are you asking for? I do see what is below in the Console.
09:23:21 **** Build of configuration Nios II for project AppNios ****
make all
The system cannot find the path specified.
'uname' is not recognized as an internal or external command,
operable program or batch file.
'sed' is not recognized as an internal or external command,
make: *** [build_pre_process] Error 1
09:23:24 Build Finished (took 2s.356ms)
